Enables the generation of ICMP router advertisement messages on one or all VLANs.
| name | Specifies a VLAN name. |
Disabled.
ICMP Router Discovery Protocol (IRDP) allows client machines to determine what default gateway address to use. The switch sends out IP packets at the specified intervals identifying itself as a default router. IRDP enabled client machines use this information to determine which gateway address to use for routing data packets to other networks.
If no optional argument is specified, all the IP interfaces are affected.
The following example enables IRDP on VLAN "accounting":
enable irdp vlan accounting
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.link-22.1"/>
